gta6 system requirments
This very much depends on what framerate you are targeting and that they target on the consoles.
PS5: 60fps
3700x: 84fps
5700x: 97fps
13700k: 135fps
Note that lowering graphics settings is often useless when you are CPU bound, some settings (such as raytracing) can make the game more demanding on the CPU but that's not the case with most settings.
Most likely GTA 6 will be made with an SSD in mind but almost everyone has that these days anyway, might still run fine on HDD if you have enough RAM. When you have more ram the game can load more data in it reducing the need to do read data from the HDD later.
But since both XSX and PS5 only has 16 GiB of ram in total (with the XSS being even worse at just 10GiB) these consoles very much need the faster storage due to having to keep a tight RAM budget (forcing the game engine to discard ram data only to have to load it into ram again later).
