Maybe the Vintologi bible should be placed on a wiki
Leucosticte
Well-known member
That would make it a lot easier to track changes, which in turn would make it easier to update translations and whatnot. (It's going to need to be translated into all the world's major tongues for prestige purposes, if nothing else, I assume)
Plus a wiki makes the formatting easy, and you can always just print it to a PDF anyway. A nice PDF should also have page numbers, btw. And if the book is divided into chapters, there should be a table of contents, and running heads at the top. https://en.wikipedia.org/wiki/Page_header
Might also want to number each section, as in other holy books.
If you place table of content in the beginning people might get bored and stop reading so it would be a change to the worse.
There would be a lot of work in setting up a wiki and it's not clear many people would read it.
Leucosticte
Well-known member
Well, if you're going to release each version of the Vintologi Bible with a version number, then I guess it's not too hard to just do a translation of a particular version. If you track changes in that ODT document, then it will be possible to more easily see what changed from one version to the next.
It's inevitable that in this day and age, a religion that attracts enough members and gets taken seriously enough will eventually have a wiki. https://www.mormonwiki.com/ (Kinda funny, Mormons have been told by their President to quit calling themselves Mormons and instead use the full name Latter-day Saints, but they still haven't changed the name of the wiki)
Leucosticte
Well-known member
A wiki only takes about an hour to set up, once you know what you're doing (which, by this point, I do anyway).
We can try it sometime as an experiment, or I can put the manifesto on Francels.com and give you credentials to take a look at it.
One benefit of using a wiki is that it will, e.g., auto-number your references; I don't know if you are having to re-number every time you add or delete a reference but if so, that sounds like a hassle.
By the way, have you seen Roosh's style of putting references? https://www.rooshv.com/what-is-neomasculinity
The ability to be a man—as according to nature—has diminished in recent years as women invade all spaces that were traditionally male, going so far as to protest to be served in male barber shops (1, 2).
It's kinda similar, but I think he starts over at 1 each time.
Leucosticte
Well-known member
Yeah, I started the process of wikification, but the main stumbling block is that MediaWiki's features for handling images are kinda primitive. They're great if you just wanna do something like have thumbnails on the side of an article, or have a gallery. Maybe not so great if you want to put images wherever the hell you like (e.g. put two right next to each other, and have them right up next to the text, like on page 1).
Actually, that might be the only place it's an issue, and even that might not matter if the images were to be cropped so as to be the same height (more details in my PM).
